daveolejnik
"I Have a 3.7 mercruiser. I pu
"I Have a 3.7 mercruiser. I put new plugs and plug wires on it and changed the oil to get it ready for spring. It runs great, but when you put it into gear you cant get over 2000 rpms and cant even get the boat up on plain. The prop is a little dinged up,but I didnt think it was that bad. Also I dont know anything about points, in the distribuiter. But seeing it ran so good until under a load I thought everything was ok. Also I put regular plug wires for an electronic egnition on the engine, And my grandfather said He thinks they use differant wires for the older point style dis. When in nuetral the motor runs great and will go to 5-6000 rpms, but in drive your lucky to get 1700rpms. I know I can change the pitch on the prop, but I am not sure if the prop is the problem, or if it is in the engine. Any info would be greatly appreteated."
