nicklanigan
Hi all,
My tilt/trim motor may have an intermittent fault (it could also be the switch/wiring etc), however given it is only intermittent it is somewhat challenging to diagnose.
The workshop manual I have isn't particular helpful in terms of steps needs to replace the tilt/trim motor should that prove to be the problem. A quick look would seem to indicate I need to:
- Support the bottom end of the motor so the load is taken off the tilt piston
- Remove the pin connecting the tilt piston to the motor
- Remove the entire tilt/trim manifold by removing a number of screws either side of the brackets
- Replace the tilt trim motor
- Top up oil level?
It looks like I'd also need a single o-ring under the tilt trim motor.
Is there a bunch more work that would need to be done?
Much appreciated as always,
Nick.
- Top up oil level?
Nick.
