nicklanigan
Hi all, time for another of my queries regarding how these engines work... note I'm not trying to fix anything, but to increase my understanding.
I'm trying to get my head around how the water system works - I've just completed a rebuilt of the power head, so have intimate knowledge of how water circulates through the power head. The limit to my knowledge is the power head, which I lifted off what is known as the exhaust adapter, so haven't opened up the exhaust adapter or anything lower.
I get that water is forced upwards by the impeller, into presumably a water channel in the exhaust adapter. That channel routes the water to the thermostats and bypass relief valves. When cold, the relief valves vent the excess pressure, dumping water out of the motor. When the thermostats are opened by warm water, water flows upwards into the powerhead. Once water has traveled through the powerhead, it enters another channel in the exhaust adapter, presumably to be expelled via the prop?
Some queries -
Do I have the flows above correct?
Is there always some flow to the powerhead, even if the thermostats are closed?
What actually warms the water to the required temp to open the thermostats? It would seem it could only be the exhaust adapter heating up from either exhaust gases or from water that has already traveled through the power head. The water passing through the thermostats must always be freshly drawn water from the impeller as it has not yet traveled through the powerhead? Is there some kind of heat exchange going on, whereby the exhaust or spent water warms incoming water?
As always, appreciate people's time responding.
Nick.
Some queries -
Nick.
