Well took the boat out this we
Well took the boat out this weekend and here`s what found. Did a link and sync. Started right up no problem. Then i Took it out for a spin and the same thing BOGGS after 1/4 throtle. So I pressed in the key to hit the choke and then throtled right up and it took off no problem. Full throtle for 15 20min no problem. Then i cycle it back and forth from full to 1/4 and it BOGGS again. Hit choke and works fine. Ohh by the way i didnt end up changing the coils or power pack as i checked the spark with timming light on all 3 holes even with the boat full out resting against the dock. Any Thoughts as to what might be happening. Installed new fuel pump and lines last year. And rebuilt carbs with aftermarket carb kits could this be the problem. If it were the high speed jet would it do the same after i hit the choke. Thanks guys for any help on this.
