flyingkraut
Does the low speed needle bushing need to be replaced occasionally? I installed a new needle and new packing, but unless I tighten the nut so much that I can just barely turn the needle, the low speed needle will eventually come loose and slip out, which can only happen, I guess if the bushing would rotate slowly clockwise in the carburetor(from vibrations?) I installed the bushing with the pointed (convex) end first into the carburetor and pushed the packing washers against the concave end, which looks right to me but I can’t tell on the drawings if this is the correct way.
