Long story: I sent my 1974 Mercury 50hp to the local dealer (same one the boat was purchased 44 years ago) to have them replace the leaky drive and shift shaft seals. Before sending it in , I had been running the boat weekly and the shifting worked fine, forward, neutral, and reverse.
I get the unit back and I'm preparing to rejoin the foot to the lower unit and I notice that the rotatory shift linkage is very loose. By loose I mean when turning it, there is zero mechanical resistance. Prior to sending it in and all other times I had worked on this to replace water pump impellers, I could easily test the shifting to be sure I was in neutral before joining it to the engine.
Though I told the mechanic to also replace the prop seals, he skipped that saying the they don't leak. The point of replacement was not to fix a leak, but as a long overdue maintenance action. 44 years is a long time for outboard prop seals.
So, I can not get the motor to shift at all, it's always stuck in forward. If I move the shift shaft all the way counter clockwise (CCW), I feel a click that takes a bit of pressure to do and it locks into position. This sets the gear box to neutral. If I turn the shift shaft all the way clockwise (CW), there is a springy feel but requires constant pressure to hold that position. This again sets the gearbox to neutral. No reverse anywhere. For the entire smooth, friction free travel of the shift shaft, the motor is in forward.
This is what I fear has happened:
The shop claimed to be very busy, so they assigned this to some new guy or the janitor. In changing out the prop shaft seal, they pulled the entire shift shaft out of the gear box. As I understand the gear box operation, this would result in unloading the cam follower, extended the spring to full out.
That would make it impossible to reinsert the cam in the proper position. So, instead the mechanic inserted it 180 degrees out of position so he could button it up. I'm guessing that the proper re-assembly would be to pull the prop shaft, position the cam in the proper orientation and then reinsert the prop shaft, properly loading the spring and cam follower.
Does this sound plausible? or am I missing something. I hate to wrench on the shift shaft in hopes of flipping it. One guy over at thehulltruth forum suggested I do just that. I'm not sure, but I don't think the cam can actually spin 360'.
So, if the shop agrees to repair it the RIGHT way, they can provide the new gear lube AND the new seals for the prop shaft, because cracking them open after 44 years will likely create a new leak. https://youtu.be/AgyeUHH_V0g
Any suggestions or advice is welcomed.
