ratherbfishin
74 Blue band mercury 500 4 cyl outbrd 50 hp. Idle is not great, stalls when going into gear in the water. Can get it to run at speed by revving, even get on plane just fine, but then stalls when go to neutral. I tested the motor by pulling the plug wires off one at a time with the engine running. With either of the lower two spark wires off, the engine speed doesn't change, but with one of the upper wires removed the engine speed drops by half and/or dies. Seems like cyl #3 and #4 aren't firing. I've replaced a lot recently as maintenance and trying to fix this including: engine wiring harness, fuel pump, cleaned carbs to the bowls and replaced lower carb needle valve and gasket. New spark plugs, tested the spark current. Fresh gas, new gas bulb and replaced a couple lines. Compression test is just fine as well. Driving me nuts here! Symptoms remain. Runs okay on the muffs in the driveway, but can't get off the launch ramp without dying. Anyone got some ideas what to do next? Thanks for help.
