My 1974 Evinrude 9.9 HP dies after running perfect for 20 seconds to 3 minutes. Time varies so I am not sure exactly what it is. First thought was fuel pump wasn't working. I had to rebuild anyways because it was leaking before. It is now rebuilt (followed the manual) and seems to be working correctly and I even double checked I put it together correctly. If I keep the primer bulb pumped it will stay running (used two different newer fuel hoses and bulb). The carb was very clean so cleaned it again just in case. Does it sound like the float needle is sticking since it doesn't always die at the same time? It revs up perfect, idles well and everything in between until it runs out of gas. Any help is appreciated. Thanks.
