billythegrape
1973 Johnson 50hp on a 24' pontoon boat.
Well, after replacing the gas cap on my engine in this thread: http://www.marineengine.com/boat-fo...1973-Johnson-50hp-suddenly-hard-to-cold-start , I was golden for a while. For reference, I use this boat every weekend, usually with 2-3 6 gallon tanks going through it.
Suddenly, the controls got wonky. The engine wouldn't start because it wasn't resting on the neutral button. Also, the warmup lever wasn't doing anything at all. I adjusted both and got it working again. Maybe the cables stretched? who knows.
My problem now is two fold. The motor is running ok, but not as well as it should be. It's almost as if something is holding it back, because every now and again it will stutter, run at a higher, more "proper" RPM, and travel as fast as it should (which granted isn't very fast). The plugs are black, chunky, and wet, which obviously indicates richness.
Secondly, it has become hard to start again. It will catch and die over and over again. If I choke it, it is worse, indicating richness. Starts just fine in the driveway. To get it going in the water, I have to raise the warmup lever to its utmost position to get it to stay running. Generally I will run it about 5 miles out to an island, park all day, then go back. It has no problems after the initial start up at the boat ramp.
New parts, time of replacement:
Rebuilt the carbs with Johnson kits- last season
Johnson coil packs- May
Johnson fuel pump- May
copper plugs- August
fuel filter- May
foot oil- May
prop- last season
Fuel is generally 91 octane 100% gasoline w/50:1 mix. Sometimes I use 87 octane 100%, but not too often, and it doesn't correlate with running issues. It doesn't smoke excessively or anything like that. I started the carbs at 5/8 of a turn out and brought them in until the engine ran smoothly, maybe an 1/8 of a turn each if that. The plastic access caps for the needles are missing from the carb housing. Engine has a decent pee stream.
What else should I check? The flywheel has some kind of brown crap that leaked from underneath it, but it looks old. Is there an ignitor under there I should worry about? What about ignition timing? Is this adjustable? How would one check it? Should I throw my gas tank out and get a new one? Should I light the boat on fire and give it a Viking funeral? HELP!!!
fuel filter- May
foot oil- May
prop- last season
