"This is my first time on this
"This is my first time on this site as I am relatively new to boating. I recently purchased an older boat equiped with a 1973 evinrude 40hp that hasn't been run in 8 years according to the previous owner. Prior to atempting to start the engine I cleaned and rebuilt the carb, replaced the fuel lines, cleaned the fuel filter and replaced the spark plugs but it just doesn't seem to want to run. A compression check showed 106psi on 1 cylinder and 104psi on the other. It also has good spark. If I pull the plugs and squirt a little fuel into the cylinders and try to start it it will sputter a few times and nothing more.This leads me to believe it is a carb problem but it has already been apart several times now with no apparent problems. Any insight into possible problems would be greatly appreciated."
