Brandon Brock
Okay, so I fixed the throttle issue. Now water isn't "peeing" in a steady stream from the motor... only sporadic, very small drops. I imagine it means I need the replace the impeller but wanted to double check with the forum first.
I let it run 1 minute with the flusher hooked up; is that enough time for water to cycle through and start to pee out?
