This is primarily for Joe Reeves..
I am trying to install the diode in your mentioned fox for voltage drop to pulse pack on this old engine.
My question is
There are 4 terminals on the starter solenoid. I will list them from top to bottom as if the solenoid is mounted on the power head below.
Top - Hot Battery (Large terminal)
Upper terminal - “S” (smaller terminal) white wire from key switch
Lower terminal - “I” (smaller terminal) white wire leading to Safety Switch
Bottom - Starter Motor (Large Terminal) 6ga red wire bridging starter motor to starter solenoid
Which terminal does the diode get installed on? Is it a separate wire (jumper) that leads from one of the starter solenoid terminals to the terminal block (Terminal 8 or 9)?
I currently have a 16ga purple jumper wire attached from the Upper “S” terminal leading to the terminal block.
I am still seeing less than 9v when cranking when probing the ignition terminal spots on the terminal block. Strong spark that jumps gap on gap spark tester on all 4 cylinders but does not want to start and stay running.
Please help!
My question is
Please help!
