Hi everyone,
I am a first timer here. I bought a boat and it ran great all last year. This year I cleaned the carbs and when I took it out to adjust it I managed to get it running smoothly. I stopped to do a little fishing and when I tried to start it the battery was to dead to start it. It was suddenly stuck in forward as well. I got towed back to the house and have started to go through the other posts and check what could be the problem. I just changed the lower unit oil with the premium blend suggested and hooked up muffs. I started the engine found the green and blue wires and checke them for voltage and got nothing which is consistent with the forward gear setting. With the engine still running I put it in reverse and get the same. I then disconnected the green and blue wires and taking an extra battery ran a jumper wire to the green wire. I started the engine again and it was still in forward gear. I then ran the jumper to both and once again I was still stuck in forward. I tried to read ohms with my multimeter but it just read overload. I believe this to mean my solenoids are bad.
What should my next step be? Any help would be greatly appriciated.
