1970 4 hp Johnson
mamarat
What is the compression on a Johnson 4 hp suppose to be i have one with just 70 pounds that's not good is it ? It has been run hot but I but on a new head gasket and had the head resurfaced.. Thanks for any help.
Squirt some fuel in the carb once and see what happens.
Already done that it don't even try to start. has good blue spark I even tried another set of plugs. I don't think 50 pounds is enough compression for it to run what do y'all think?? I have another one just like it and it has about 90 pounds on it.
Do a compression test with rope directly on the flywheel.----If spark can not jump a gap of 1/4" on a test device you have a " no spark " condition.-----Laying plugs on the block is not a good test.----A waste of time !----With fuel in the cylinders it should bark at least.---Unless leads are on wrong plug.
