Ive cleaned the carb twice, just put a new fuel pump kit on. I can get the motor to start but if I run it at low RPMs it will kick/sputter and then when I give it gas it hesitates/sputters until it reaches a higher RPM. Then it seems to run okay at the higher RPM. Also noticed the top cylinder where the spark plug goes in is very hot when running whereas the bottom is only warm..?? Not sure if that means anything but Im not sure what else to do.. any suggestions??? Ive also tried adjusting the idle screw.. it has a Tillotson MD carb which only has one adjusting screw.. as far as I know anyways.. still wont stop sputtering/hesitating..
thanks
thanks
