"Hi all, I'm new to the ou
"Hi all, I'm new to the outboard scene, so forgive me if this seems elementary.
I recently bought a used 1968 9.5hp Evinrude. I replaced the plugs, cleaned the fuel pump, replaced the fuel line and bulb and cleaned the screan on the pick-up line in the tank. My problem is that it doesn't want to run at wide open. If falls on it's face after only a few seconds. I've only had it out twice and the first time it would wind up and run fine for 15-30 seconds and then fall back to what seems to be about half throttle. Now it doesn't want to wind out at all and goes from half throttle to idle. If I run it at half throttle, it runs great. I noticed that the bulb does not stay firm when running, and the motor seems to run better if I keep pumping the bulb.
I'm assuming that this is a fuel delivery problem, but I don't know where to start looking. Any suggestions?
Thanks."
Thanks."
