smoothsalin
I bought a 1951-52 Evinrude 7.
I bought a 1951-52 Evinrude 7.5 o/b recently and the first day i took it out i ran it for a good 40 minutes without shutting it down and it ran fine. The 2nd time out it ran fine for a bit but seemed to be overheating and dying and when i tried to start it the pull rope was hard to pull almost like it was locking up but after a few minutes it started and ran for a couple of minutes and died again. Once again it was smoking at the top and the sides of the motor was hot to touch. I did check the water punp and it was pumping water out however it looked more like steam coming out when i was running it at a higher speed right before it died. I also noticed the fuel shut off was leaking some gas when the motor was not running (not sure if that has anything to do with the heating problem but i thought i'd mention it) does anyone have any idea's as to why i am over heating? Can being low on the fluids in the lower unit cause the motor on top to over heat? Any information is greatly appreciated...Thanks in Advance
