Well it sounds like it's running fine and you definitely don't have too much boat for the prop.
It's possible that it's simply your expectation of the hole shot is not what your getting - might be nothing wrong at all (if you follow what I'm saying here).
If you normally "take off" with the motor fully trimmed down, try bumping it up a bit - you may experience some prop slip but that might be what you need to improve the low end.
A (perfect hole shot) is created when:
the prop quickly spins up
the quick spinning causes some ventilation (a layer of air around the blades)
the water finally collapses back against the blades causing them to "bite" and propel the boat forward
If the prop is too big to turn quickly and you don't get ventilation your hole shot will suck
If there is too much hull drag, when the prop "bites" it may not have enough thrust to overcome the drag sufficiently to give you a good hole shot (dirty hull, soggy hull from water intrusion through gel coat, too much weight forward of the center of buoyancy).
