1988 Evinrude 150XP, E150STLCCA
Motor runs well but tach not working and voltage gauge reading 11 volts with good battery. Use to read 17 volts.
I have:
Connected grey wire (for tach) to yellow/grey stator wire at terminal strip (per Joe Reeves) and tach will work. Although it reads about 1800 rpm when motor is actually running about 775 rpm. So the Reg/Rec must be bad. I am assuming tach will read correctly when I replace Reg/Rec.
Static checked the stator per the Evinrude Service Manual and it seems to check out OK. Wondering about it though. Especially since this is the second Reg/Rec in a few years and I don't think the voltage ever read correctly even after the new REG/Rec a few years ago.
Any thoughts on why the Reg/Rec keeps going out?
Any other good ways to check stator?
I know its an old motor but would like to keep it going for a while.
I have:
