15 HP Mercury 4-Stroke Static timing
mills
Got a 2006 15 HP Merc 4-Stroke that I removed the cylinder head and moved the flywheel. In order to set the timing I think that I need to set the flywheel on the TDC line and then turn the camshaft sprocket to number 1 pointing toward the flywheel, then install the timing belt. Is this correct? If not set me straight. Thanks ..................
