Got a 2006 Merc 15 HP 4-Stroke Outboard that I'm trying to save. There is water getting into the oil so I want to inspect the head gasket/cylinder head to see if that is the problem. Removed all the bolts that hold the head on but can't get it off because the oil pump is jammed against the lower cover and will not allow it to clear. If I remove the bolts holding the lower cover on will this allow me to remove the Cylinder Head??? Or can I do it by cutting out 1/2 inch of the lower cover so that it will clear and I can remove it?? Can't find a Merc manual at our library
