Looking for Experiences and advice on turning my 1997 Mercury 115 hp outboard from a 2 by 4 running cylinders into a 4 x 4 running cylinders.
As all who have experiences with this engine. The engine runs on 2 top cylinders when below about 2000 rpm and then kits in the two bottom cylinders when runs above about 2000 rpm.
The bottom 2 carbs are Identical to the top 2 carbs with the exception that the 2 bottoms carbs lack Idle screws.
Question,
Has anyone removed the 2 screws plugs and installed Idle screws allowing the bottom carbs to work at all rpm levels.
I would imagine the timing would need adjustment and all carbs would need to be tuned and synced.
any and all comments wlecome
Redhamil
Question,
Redhamil
