"Sadly, after working hard for
"Sadly, after working hard for five months and finally getting it running good, She let go. I was cruising at 3200 with normal temp and oil pressure and it made a deathly noise. Upon inspection, there was a hole through both sides of the block on the lower end. You can look right through. I assume it was the work of a loose rod. Any suggestions on finding a replacement? I hope maybe I can just replace the whole block and it's components, assuming the head is not damaged."
