stevenelson
" Sparky, thanks for helping.
" Sparky, thanks for helping. Could you tell me if it makes a difference which vaccum hose goes to which intake manifold nipple? They gave me 2 vaccum hoses with the carb set. One has 2 outlets, one has 4. Background: The motor{89 200hp Johnson Looper} flooded when I had the motor tilted up quite a ways while we were idling out during a low tide. When flushing, I found gas leaking, and subsequently found 3 carbs, vaccum hoses and inside of silencer box all partially melted. I did not here a backfire,nor did we see any smoke other than when initially starting after flooding. Any ideas as to the underlying cause? The heads do not show any signs of overheating. How could 3 carbs melt without even knowing there was a fire? I am switching to 225 carbs. The timing appears to be the same for both engines. Do any changes need to be made? Thanks again for any advice. "
