"Ofcourse,it almost goes witho
"Ofcourse,it almost goes without saying that the throttle linkage/cable setup must be adjusted up w/o any slop or delay of throttle. (there, I said it!) anything like that could affect sync. The idea here is same exact setup on both engines. both engines rev up from idle to WOT in perfect syncronicity like "ONE" big engine! Watching both Tachs during slow revs is a great way to check your work! It helps it the Jetting( IE Richness Setting) on each engine are close to the same too as one motor lean and one motor rich will start off equal (after Syncing) but will increase RPM at different rates and say at 3/4 throttle Eng. A will be at say 3950 RPM and Eng B will be at 4000 RPM. This is NG. Alot of info, I know but alot can affect sync. And that is assuming one of the engines doesn't have a vacuum leak, poorly sealing rings ect. Hopefully a Vacuum gauge/ sync device is steady and not bouncy or low/erratic @ idle on both engines-This is a good sign that all is well in both engines!"
