"Hello,
I just took my proj
"Hello,
I just took my project boat out on the lake for the first time. It is an AQ 131 with fresh water cooling. When running it on muffs, it ran at about 175 degrees, but out on the lake it was at about 200, maybe even as high as 210 degrees, a little too warm for my liking. It has a new thermostat, impeller, anti-freeze is full, raw water intake fitting on the outdrive has been replaced. Can the exhaust manifold be causing my problem? How can I tell if it is plugged? I did notice that the manifold was warmer than when I ran it on muffs, and a little warmer by #4 cylinder compared to the other three. I know it is a raw water flow problem, just wondering if the manifold is causing the problem.
Thanx for your help.
Rob."
I just took my proj
"Hello,
Rob."
