J
Jim G
Guest
"I have a 1986 AQ 131 A. This
"I have a 1986 AQ 131 A. This has been a great little engine for the past 5 years. Last year, I developed an exhaust leak around the exhaust port on #4 cylinder. This resulted in the engine overheating unless I ran with the engine cover off. Figuring I had a hole in my exhaust manifold, I didn't tackle the problem until this spring. I removed the exhaust manifold and discovered a piece of the exhaust port on the cylinder head has either cracked away or corroded away exposing what looks like an iron ring that lines the exhaust port and a 1" X 1/8" crack behind it where the exhaust is escaping. Any attempts to seal up the crack by brazing have been unsuccessful. I am not particularly skilled in that area. Plus, it looks like dissimilar metals. The ring inside the port appears to be ferrous metal and the cylinder block aluminum? I've priced new cylinder heads and they cost more than the boat is worth. Anyone have any ideas?"
