"To correct an overheating eng
"To correct an overheating engine, I have managed to change the thermostat, flapper, and impeller...and a few gaskets along the way. Reading the Seloc manual, I believe that I put it back together correctly (lower unit). No spare parts anyway. Two questions though. While running the earmuffs on the lower unit with water flowing, I get a fairly steady stream of water that squirts from the lower area of the shift shaft arm. The water seems to come from the lower unit pump. When I matched the lower unit and upper gear housing together, they slid together correctly with the impeller tube lining up properly.
Secondly, the manual says that the short arm of the shift shaft must face forward when mating the upper gear housing to the lower unit. This doesnt seem to make sense because it barely seats in the metal slot on the upper gear housing. Shouldnt the long end sit in there? Seems to fit better with no slack. With the long end in the slot, it seems to shift better too.
Anyone?"
Anyone?"
