"I have a 02 Volvo Penta 4.3 G
"I have a 02 Volvo Penta 4.3 GL-A. After Running at Wide open for a 30-90 sec I would get the Warning Beeping. I assumed it was the Impeller, so I checked it and there was a tooth sheered off and clogging the inlet a bit. I cleared it out and replaced the impeller. At the same time I Changed my oil (Volvo Syn.30), oil filter, and fuel filter.
It is still still beeping after a top speed pass of 30-90 sec. but if I let off throttle to a stop, the bepping will stop after 5-15 sec.
Here is what my gages are reading at top speed.
Water Temp = 175-185
Oil Pressure = 55-60psi
RPM = 4600-4700
Any suggestions...........
Are there exhaust sensors on here that I can check?"
RPM = 4600-4700
