S
Steve W.
Guest
"Hi all and thanks for the hel
"Hi all and thanks for the help you have given me so far. Have a 1987 4.6 I removed the entire outdrive as the dog clutch was about to go and installed another lower unit, have all new gaskets and O-rings, bellows, etc. What I need to know is, is there an easy way to check the shift cable for adjustment to make sure it is correct since I have all this off? I looked at the Stuart web site and can't make it out. The cable is only about 7 months old and shifts easy as it was replaced with the new engine so it is fine. The shift rod, I seen to measure it 7" and something?? , but measure where from to where to? Also seen a threaded end on the cable, this one is tighentend up all the way on my outdrive? Thanks!"
