i have an 86 mercruiser 170...
i have an 86 mercruiser 170...alpha 1 sterndrive...i removed my lower unit to change the water pump...after inspecting the lower unit i see a "what looks like a nut" it looks a little corroded but im not sure what it is...ill try to describe where exactly it is....if you were to look at the unit as if it was still attached...it is on the back end...you have a bolt there that attaches the unit to the upper...well just in front of that towards the prop side there is a small rod with "that nut" on it...what is that? should it be replaced?
