J
John Milliron
Guest
" I have a 1988 50 HP Force tw
" I have a 1988 50 HP Force two-stroke outboard on a 16?Grumman deep V that has run good until now. Ran it the morning of the 4th of July no problem, but that evening it started up good and ran good for about 150 yds then started to dog. It lost RPMs and power and stalled when I brought it back to neutral. It would start in warm-up but not at full RPM.
Cleaned full filter
Plugs look good & regapped
Can get max RPMs in neutral manually
Can NOT get max operating range RPMs in gear
Does not sound like there is a miss
Noticed small amount of FEUL oil not lower end oil next to the shift rod
MODEL# 507R8C
Ser# 1095
Does anyone have ideas to help me correct this problem?
ps ?I had run ¾ of a tank of gas before problem so it is not bad gas. "
Cleaned full filter
MODEL# 507R8C
Ser# 1095
