Flywheel Nut Torque
jrs
"What should the flywheel nut
"What should the flywheel nut torque be on a 1965 Johnson 6 hp?
Also, what's the best way to replace the starter rope? Can I just pull the rope out and hang onto the spool while tying the new rope onto the spool, or is there a better way?
Thanks"
"Rope installation in pdf form
"Rope installation in pdf format:
<center><center><table border=1><tr><td>http://www.marineengine.com/discus/icons/mime_pdf.gif""" align=left alt=""application/pdf"">rope
[url=""][b]rope1.pdf[/b][/url] (166.3 k)</td></tr></table></center></center>"
"Thanks, Andrew! Yep, your way
"Thanks, Andrew! Yep, your way of replacing the rope looks a lot better than mine."
