"Fatboy.... If at any time you
"Fatboy.... If at any time you or someone has hooked up the battery backwards, or connected a battery charger backwards, that would destroy the rectifier. The rectifier converts AC voltage (which is the output from the stator) to DC voltage.
What type rectifier do you have? Is it a water cooled voltage regulator/rectifier assy that's on top of the block in back of the flywheel, or a small one that is located on the right (startboard) side of the engine near a terminal block? (I don't have the 1997 parts book here at the moment)
Joe (30+ Years With OMC)"
