I have a Mercruiser with a 350
I have a Mercruiser with a 350 and Apha II outdrive. I just removed my out drive and replaced the water pump and all the hoses including the bellows. When I put the boat back in the water there is a leak coming in the boat where the outdrive connects to the transom. Water is pooling into the rectangular box above the drive shaft and dripping down on to the shaft and into the boat. It seems to be where the shifter arm is connected. I have a manual and it doesn't show or talk about what it would take to fix this problem. Is there a seal in there and do I have to remove the outdrive again to fix this kind of leak. Does anyone know how to fix this and can you give me the steps to do it. Thank you in advance.
