"I go to rebuilt the water pum
"I go to rebuilt the water pump on my 1988 Mercury 50 HP 3 cylinder 3 stroke I already removed the bolts off on lower unit but is there a plastic nut with a little nipple and small hose connected. So far the major problem is the removal because I'm afraid cannot be turned without break if I apply more force.
Is that speedometer tube in the lower unit? If so how do I disconnect it?
On the book Diagram show number 2 part # 85822A1 CONNECTORASSY.
What’s that tube for?
http://www.boats.net/parts/search/Merc/Mercury/1988/1035203BC/GEAR%20HOUSING%20(DRIVE%20SHAFT)/parts.html
Thank you for your help.
