1954 evinrude
efrhd
I went through the carb and re
I went through the carb and replaced the coils set the points to .012even tho it says on the flywheel to set at .020 and it still wont start except a few "poofs" now and again can anybody help (please)
"Setting the points to .012...
"Setting the points to .012.... that'll keep it from running.
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubber portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
well i tryed setting the point
well i tryed setting the points at .020 again but still got the same end results got anything else?
