aday_in_nh
"I successfully installed my E
"I successfully installed my Edelbrock 1409 onto my M360. As others have commented, very easy and straightforward install. Low idle mixture screws are set but I can't seem to get a smooth transition to higher rpm's. In other words, when I accelerate from 8-900 rpm's, when going through 1100 the engine will stumble. If left at 1100, it will continue to stumble along until you accelerate above 1200, then she's smooth.
Any help from the group would be appreciated.
PS - if you do a skiboat start (idle to WOT), there is no hesitation.
Thanks."
Thanks."
