"I am replacing heads on a 199
"I am replacing heads on a 1997 5.7 (350) Mercruiser. The new gaskets (Detroit Gasket) are solid stainless steel. The Mercruiser manual states to use 'Quicksilver Pro-gasket Sealer" with ribbed gaskets. I have never used a sealer with head gaskets.
What is everyone's thoughts on this?
The gasket looks very similar to the one pictured here: http://bpi.ebasicpower.com/mm5/merchant.mvc?Screen=PROD&Store_Code=eBasicPower&P roduct_Code=DET59211HS&Category_Code=GASK-HS
(Yes I realize that set is for a V6, but the image shows the same type of head gasket.)
Thanks!"
Thanks!"
