knuckle47
Advanced Contributor
"In the few years I have faith
"In the few years I have faithfully learned so much from this web site, I always try to explain my results in case someone else may find a benefit as I have... Here goes. THIS IS A TEST as inspired by FastJeff....
The short test data is : WOW ! WOW ! GEE WHIZ !....for a more detailed observation, read on:
Several posts are mentioned by this highly experienced floating wizard with regard to overproping the boat. To boil down his comments it is my INTERPRETATION that with 454's spinning larger wheels, it would be difficult to bog the engines down with bigger props but it is do-able. After 2 years of looking I'd FINALLY found a set of 21 x 23 4 blade props to replace my original 18 x 20 3-blade ones.
I knew in advance that these were going to be a BIG increase in prop size and can likely drop my 5000 rpm down 1000 or so...HOWEVER, the engines had NO trouble in getting the rpm's up and going... AT ALL, and the short story is, I might take them to a shop NEXT WINTER to take out a little pitch, MAYBE . Right now they seam really really good...I have no complaints in the quick 4 mile run we took to get gas at a local marina.....possibly 21 x 21.5 or 22 is a better way to go. I can easily reach 3600- 3800 rpm... and top speed was reached VERY quickly at about 28.5 knots but I did lose about 1200 rpm...IF I CAN GAIN 500 or so rpm, maybe it can be back at 32 knots. FUEL burn rate at 28.5 was about 43.5 gph, cruise at 3000 was a nice 23.5 knots.
Fuel economy indicated on the Garmin integrated GFS 10 was about .8 nautical miles per gallon at speed which was usually around .6 or even .5 ....HERE IS THE REAL THRILL....Once you get out of the no wake zone and hit the throttles, you get pushed into the seat a bit from the g force of acceleration, reminiscent of the 1969 Firebird or Z-28....The old props almost felt like they were trying to push the water out of the way so they can get moving. We hit plane within 15 seconds. My brother and I were both very highly amazed and impressed. No out of balance vibrations either so the prop shop can wait till next winter....At slow maneuvering speeds, there is a NOTICEABLE bite from the forward and reverse action on the shifters and the immediate reaction of the boat makes PRECISE handling for docking type slow speed stuff quite impressive also...
Here are my new questions....
I believe we are reaching full Delco EST distributor advance at this rpm so I am not affecting that parameter or overheating....True?
My timing setting currently are exact 11 degrees so that should be fine, I get no engine detonation the engines respond IMMEDIATELY....true?
Will extended Full throttle running at 3600 or so be problem since this is now the new WOT, I think not since the engine design suggests 4400?
Is it advisable to increase IDLE speed or MIXTURE to account for the BIG BITE these props seem to take from a maneuvering stop and go event which causes my port engine to SOMETIMES stall? This was not a problem with the smaller wheels as my idle speed is textbook at 675 rpm +/-....Thanks Again all....
AND, as for that steam thing...it was very humid today but at 3000 or above, I get this with 140 on the gauges
Jeff......Fantastic !
steam trail
