"you need to get the mark on t
"you need to get the mark on the pulley at the bottom front of the engine to the ZERO mark on the pointer, The mark will be there 2 times during the #1 cycle (int, comp, power, exhaust) so this will be there when #1 is ready to fire and when #4 is ready to fire, you line it up for #1, put the mark as close to the zero mark on the pointer as you can then drop the dist in with the rotor pointing to where you want the #1 wire to be, tighten enough so you can rotate the dist but not too loose that it will flop around.
If when running it backfires through the carb, your 180 out, simply remove the dist about 1.5" reverse it 180 degrees to point to #4 wire and drop back in, it should then fire properly.. (hope that's clear)"
