"You would'nt believe the
"You would'nt believe the deal I got, but the port motor needs a head gasket. Is there a way to identify if it's a wedge motor or standard 318 other than the casing number? The boat is stored at a marina that is a good 65 miles from my house and I need to get that motor fired to relocate her closer to home. The motors are rated at 225hp if that helps. The motor is on a closed cooling system which would affect the type of gasket I need right? Thanks for your help guys..."
