Results 1 to 9 of 9
  1. #1
    Join Date
    Apr 2007
    Location
    Port Saint Lucie, Florida, USA
    Posts
    15
    Default My steering on my 1979 OMC 800
    My steering on my 1979 OMC 800 2000 Taira outdrive is hard to steer. How do you remove the steering bracket? Do I have to remove the engine first (I hope not)? Has the true steering. The steering bracket with cable and shaft is right behind the engine with close quarters.
  2. #2
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,211
    Default "Assuming you do not have powe
    "Assuming you do not have power steering, you have to remove the outdrive and slide the shaft out the rear of the intermediate once the drum screw is out. But I wouldn't just go taking that off because it's hard to steer - I'd diagnose it first. Grease the swivel bearing in the outdrive, grease the steer shaft. etc...
    Did it get gradually stiffer - or just all of the sudden hard to steer?"
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  3. #3
    Join Date
    Apr 2007
    Location
    Posts
    15
    Default "The steering got stuck all of
    "The steering got stuck all of the sudden. Had to use a hammer to get it loosen. Did the grease thing, no good. It turns but hard. Took the outside gear off and the bushing looks bad or torn. Took the only screw I could find out, about 3 inches long. I don't see any other item to undo except the bolt that holds the steering bracket on the intermediate housing. Try to tap the shaft out but it will not move (out toward the sterndrive).
    follow links for pics.
    http://i169.photobucket.com/albums/u.../steering.jpg"
    http://i169.photobucket.com/albums/u...Work/saft.jpg""
  4. #4
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,211
    Default was the steering still tight a
    was the steering still tight after the drive was removed? That screw in the first pic is the only screw that needed to come out when I did mine as I recall.
    The plastic cap is still on the grease fitting in the first pic. looks like you got grease everywhere but in the grease fitting.
    The grease fitting in the second pic isn't greasy either....
  5. #5
    Join Date
    Apr 2007
    Location
    Posts
    15
    Default "yes, the steering is still ti
    "yes, the steering is still tight with the outdrive off. You can see in one pick that the rubber bushing is damaged. If I take the screw out I sould be able to pull or tap the shaft out. I tryed and it did not move. Is there a slot on the shaft that that screw goes in to to keep the shaft in?
    I did put grease in each fitting and replaced the cap on the inboard one. Don't have a cover for the outside one."
  6. #6
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,211
    Default yes there is a hole through th
    yes there is a hole through the shaft that the screw goes through. Will have to get some good penetrating oil into the bushings and let it sit for a bit. Put the gear back on and try a heel bar against the gear to draw the shaft out.
  7. #7
    Join Date
    Apr 2007
    Location
    Posts
    15
    Default "Thanks for the help HY Stat.
    "Thanks for the help HY Stat. Used a heel bar and it came right out. I wanted to make sure I wasent going to screw something up. Thanks again."
  8. #8
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,211
    Default later on when you put that scr
    later on when you put that screw back in the drum - be careful not to overtighten it - it is just threading into the aluminum drum and can strip out easy -not an easy fix if that happens
  9. #9
    Join Date
    Apr 2007
    Location
    Posts
    15
    Default Thanks for the heads up. Thank
    Thanks for the heads up. Thanks again for the help.
Similar Threads
  1. steering fork removal
    By tedm2 in forum Volvo Penta Gas Engine Forum
    Last Post: 04-27-2010, 12:59 PM
  2. Steering arm removal
    By woods2641 in forum Volvo Penta Gas Engine Forum
    Last Post: 09-20-2009, 11:51 AM
  3. Removal of OMC 1979 Series 800 Lower Stern Drive
    By jmayfield in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-10-2009, 08:42 AM
  4. Steering Cable for a 1979 Evinrude 70HP
    By dhungy in forum Johnson Evinrude Outboard Archive
    Last Post: 04-29-2008, 09:50 AM
  5. 1979 Evinrude V6 175 hp changing steering cable
    By Joe Anaya in forum Johnson Evinrude Outboard Archive
    Last Post: 08-23-2003, 11:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
