Greetings. I have a 1965 Evinr
Greetings. I have a 1965 Evinrude 33552. The engine overheated and I pulled the lower unit to check the impeller. The impeller is getting replaced but the problem was in a small rubber gasket that fits inside the top of the impeller housing water outlet and provides a seal between the outlet and the water pipe up to the powerhead.
The gasket split near the bottom and a piece of it blocked the waterflow. I need to identify this part by name or part number. I can't find any replacements for it for my engine model.
Your help is appreciated.
