"Hello everyone,
I was dire
"Hello everyone,
I was directed to this site from the OMC site due to having an outboard. I have a V4 OMC SeaDrive Outboard that I cannot set the timing. The engine is sputtering at idle and miss firing when reved. Set TDC marks on flywheel for all cyl..used timing light to check #1 but when I turn the timing screw in or out the mark does not move. I am moving toward a bad power pack or timer base but not sure. Don't want to start replacing good parts if not needed. Bypassed onboard gas tanks ruling out bad gas. Any help on this would be greatly appreciated.
Thanks,
Les"
I was dire
"Hello everyone,
Thanks,
Les"
