"My first post and sorry if I&
"My first post and sorry if I'm repeating old discussions. I've been searching the forums and there's a lot of good information there.
I've got an AQ151C that idles poorly, cuts out and hunts up and down the rev range. I thought it would likely be carb related, but I had a mechanic look at it yesterday and he initially looked into the ignition circuit.
When running, we pulled out the plug leads from 1,2 and 3 in sequence and it didn't make a great deal of difference to the running of the engine, so it looked like 4 was doing the bulk of the work.
I've replaced the plugs today and ordered up a set of plug leads, since I suspect they are the originals. I also had a pop at checking the timing with a strobe and it looked like it was at 10-12 BTDC when it should be 6. Would this be enough to make it run poorly at idle or do the symptoms still sound like carbs? At speed it seems OK, it pulled 5500RPM at the weekend, it just doesn't like going slow.
I've also followed the discussions on converting the points to Petronix electronic ignition and I'm trying to source an Ignitor and Flame Thrower coil for the engine.
Thanks for any advice."
