"Walter,
Are you doing a co
"Walter,
Are you doing a complete overhaul of the TB, ie. teardown, gasket kit, etc, or are you just looking for PM? If you are doing a teardown your best best is to soak the TB in a gallon jug of carb cleaner overnight before rebuilding. If you are doing PM then I would recommend an aerosol can of carb cleaner and an old toothbrush. Be careful though, some EFI sensors do not agree with carb cleaner. Look for a carb cleaner that says "sensor safe".
As a side note, 'cleaning' your TB only frees the throat from carbon buildup. You may also want to run some injector cleaner through your system to keep your injectors operating efficiently. I am a fan of the Lucas products."
