Pulling sterndrive SP volvo penta 1990 AQ211A for the first time special tools
ponti
Newbe - Pulling volvo sterndri
Newbe - Pulling volvo sterndrive SP for the 1st time do I need special tools and is this a diffucult task to get it on and off. Want to check bellows etc
Good for everyone to follow th
Good for everyone to follow the link if you don't already have a manual for your outdrive. download it to your pc for future reference.
"Question - Overall, easy to p
"Question - Overall, easy to pull stern drive to change bellows or hire a real mechanic??"
"Changing the bellows (eit
"Changing the bellows (either the drive or the exhaust) is a piece of cake, you should be able to do it yourself. For the drive bellows, the easiest way is to remove the upper gear assembly, but you can also change it by removing the whole outdrive and pulling it away from the transom shield a few inches.
You may want to do a search in the forum, as this topic has been discussed several times."
