Mercruiser Bravo III drive oil leak
aitkens
"My Bravo III drive has an oil
"My Bravo III drive has an oil leak that the marina is having trouble finding. They just changed both prop shafts because of excess wear ,(groove cut around both shafts at rear seal, possible causing leak), this did not stop the leak. The oil quantity in the resovoir goes down to the fill mark after about 2 or 3 hours of use. Doesn't seem to be leaking in bilge. Any suggestions where to look for leak."
pinch off hose going to resivo
pinch off hose going to resivor and pressure check drive if you cannot find leak remove the outdrive and look in bellows for oil
"the hose from the resovoir to
"the hose from the resovoir to the outdrive was already changed. are the bellows in the upper section of the outdrive, and what are the bellows used for. thanks for your help"
"I had a similar problem with
"I had a similar problem with my old Alpha One drive, and I rationalized it this way: oil is cheap! Consider how much oil you need to add in one whole season and I'll bet it's less than 10 bucks! Of course, should the level start dropping far quicker, then you need to act.
Jeff
PS: Most Merc outdrives tend to use SOME oil."
