"Thanks Graham, I'm runnin
"Thanks Graham, I'm running this on a 8' Marsh Boat so a 5 Horse is about the biggest I can run on it.
I was just looking to get a little more out of the motor.
I'm already shopping for a replacement, this motor's left me stranded twice now, the last time was on a long run & the motor was overheating Big Time, the hotter it got the weaker the motor ran, til finally it konked out.
The motor actually siezed up & I couldn't pull the starter rope, after an hour I could budge it loose a bit & after another half hour I could pull the rope enough to get it to fire.
I can literally feel the motor lug down as it heats up, throttling it down & running it at lower speeds helps, but even then it will heat up aswell.
I'm running it on 24:1 with a new fuel tank & fuel lines. I've replaced the lower unit oil 3 times, the old oil was in there for quite a while, so its fairly thick & tough to flush out.
I think all the old oil is out now, so I'm sure thats not part of the problem.
I know the power head is Air cooled, & the shaft is water cooled.
All the heat is from the power head down, even the mounting bracketts are heating up.
I'm pretty sure its on its last leg but If I can get a little more out of it I will.
Have you ever heard of putting Marvel Mystrey Oil in your fuel at a 1 ounce to 1 Gallon:mix ratio??
The local outboard guru told my dad to do that with his 5 HP Johnson. Basically he said the Marvel oil would penetrate where the 2 cycle wouldn't.
Thanks Lee"
